Speed meter location
Discussion in 'Problems, Fixes, Tips...' started by stelios ioannidis, Jun 18, 2018.
  1. stelios ioannidis
    stelios ioannidis Copenworld Newbie
    greece
    daihatsu copen 1.3
    Hello i have a P0500 code in my OBD.The code is about the speed meter sensor.The problem
    is i cant find the sensor,i removed thr bumper,the battery,the base of battery and air filter box
    i checked the transmission but nothing.Do anybody can help me?
  2. jez77
    I've looked for it before and concluded the ABS sensors must provide the speed signal.
    I've never managed to find where it goes into the Ecu or speedo
    Vin Petrol likes this.
  3. stelios ioannidis
    greece
    daihatsu copen 1.3
    Hello thanks for your reply.Maybe you have right,i search all the places which can be the speed meter,the strange is that i can find the sensor as part in internet and seems that isnt part of ABS system.
    So i have to find ABS sensor and to clean or to test in omhmeter.Thank you.
  4. Vin Petrol
    Well I've found a thread that shows the actual wire, that presumably should be traceable to the sensor - plus if you're lucky, the wire could be the problem. It's in a wrapped bundle of wires running under the centre console according to this thread:- DIY: Open roof while driving
  5. jez77
    Id say the wire they are referring too is a speed signal coming from the the engine ecu going to the roof Ecu but I'd like to be proved wrong.
  6. Vin Petrol
    That does seem likely although it wouldn't actually be a speed sensor wire in that case. Seeing as it was translated from Korean though, sensor/signal...you're probably right. :-/
  7. Salieri
    Check the ABS rings and the respective ABS sensors
  8. stelios ioannidis
    greece
    daihatsu copen 1.3
    Thank you everybody for the informations,you had right about ABS sensors,i remove the right and left ABS sensors from the whells,i cleaned them (3M and carb cleaner) and engine light after install disappear from panel.
    Thanks for yor help.
