Auto transmission oil change
Discussion in 'Problems, Fixes, Tips...' started by Paul j, Nov 30, 2017.
  1. Paul j
    Paul j Copenworld Newbie
    new zealand
    anyone know where auto trans fluid filler is located please changing oil on new purchase
  3. welz
  4. welz
    automatic Transmission oel change is not so easy..
    checking oel : start engine , push brake...change gears manual ..with engine on . check dipstick.. dark oel change, if red oel only fill up to sign on dipsick. i dont know the real oelchange intervalls. maybe userbooklet?
    change : lower screws on oelpan little bit..complet after most oel had leave. change filter inside and oelpanseal . careful with the nm from the screws after rebuild.
    you must fill up the new oel through the dipstick filler.
    check again after refill and after 10 -50 miles. how much oel you need? check how much was the old on. sorry no idea.. think maybe dexon III.
  5. Salieri
    I'm terribly sorry if that is the case :O
    Must be a Japanese import then
