What is this button for?
Discussion in 'Problems, Fixes, Tips...' started by adrian, Jan 4, 2011.
  1. adrian
    adrian Copenworld Newbie
    Guys, i just bought a 2nd hand copen.
    One of the buttons, the one just below the handbrake with the arrows pointing in opposite directions, doesn't work for me.
    What is that button supposed to do actually?
    sounds like a stupid question i know..
    thanks in advance
    As far as I'm aware there are five possible buttons to press around the handbrake.
    The heated seats buttons are above the handbrake.
    The two below these, slightly lower than the handbrake are for the windows.
    The one under the handbrake is the switch to put the roof up & down.
    From your description I'd guess it was for one of the windows.
  3. Adam K
    I had at look at mine on the way home.
    I'm not so sure it us the window button. Mine dosen't have an arrow on.
    Can you post a picture of it?
  4. Lotuseater
    Lotuseater Copenworld Regular
    1.3 Copen
    Hi,
    Looking at the handbook, the one directly below the handbrake is the roof operation.
    Hope this helps.
    Lotuseater.
  5. Adam K
    The roof operation button has a picture of the car on it though with the roof opening. There are no arrows.
    The only button with arrows facing the away from each others is for the electric mirrors. This button is on the LH side, behind the steering wheel.
  6. honeyjew
    honeyjew Copenworld Member
    Might be an after-market button? Possibly something to do with the alarm or the immobiliser?? Or more likely the parachute deploy or emergency ejector seat :)
  7. adrian
    thanks for the input guys, just got it back from workshop will post a pic of it tom..
    i think it was some modification done by previous owner
  8. Nightwish
    Nightwish Copenworld Newbie
    Most probably the roof button. Make sure your canvas at the boot is pull up and hook before you can open the roof! If not it won't work!
  9. Randy
    Randy Copenworld Newbie
    Gtr Manchester
    Must admit, i`d never buy a copen without already seein the roof go up and down... Surely it can`t be the power roof button... can it? :think:
  10. jmaboko@gmail.com
    jmaboko@gmail.com Copenworld Newbie
    Are these buttons for heated seat?
    Hi Guys
    I just read your discussions about these my mysterious buttons. I have the same question regarding the two buttons above the window opening switches. I have the 1.3L 2006 Copen.
    Would I be correct in assuming that these blanked out buttons are for seat warming?
    If I connect a switch onto the green connector I found inside the arm rest would the seat warmer work? This would be nice for South African winter.
  11. jmaboko@gmail.com
    I found this page from the Copen Manual that I downloaded from Copen World (Thanks to Adam ;) ).
    So these buttons are for seat warmers. I just need to get two switches and try warm up my booty. Lol
  12. Ashley
    Ashley Copenworld Member
    Cape Town
    Merc estate
    RAV4 3-Door
    I don't think that's going to work...:(
    The expensive part is the heater element which is in the seat itself that's the part which is needed - not the switch.
    Mind you, if you try it and it works, let me know - I have the same thing in mine.
  13. Rex
    Yep, that's for the bum warmers. I think only fitted with the leather option seats.
  14. Ashley
    Cape Town
    Merc estate
    RAV4 3-Door
    Mine also has leather seats - but (apparently) no bum warmers and blanked off switches.
    I'm guessing that Daihatsu decided that in "Africa", it is plenty warm enough, so we wouldn't need them?
    Now if they actually fitted the heater elements, it seems unlikely that they would try to save the pennies by not fitting a couple of switches? More likely that they didn't fit the heating elements either.
    Mind you, I will be happy to be proved wrong - if I am, then I can also upgrade my seats for the cost of a couple of switches.
    Probably easiest to check by finding the terminals in the switch connector that connect to the heater elements and checking the resistance across them with a multimeter - Zero = short circuit, Infinity = not connected, something in between means that an element is probably present.
    I'm away from home now (so I can't try it), but if anyone has success I'd be glad to hear about it.
  15. Ashley
    Cape Town
    Merc estate
    RAV4 3-Door
    Also you could try looking under the seats - if there are heaters in them, there should be a couple of wires going from the car to the seats.
    If anyone with the bum warmers fitted, could check this theory and if you find the connecting wires take a picture and post it, then we should be able to find out whether it is possible - Please?
  16. skyecn
    skyecn Copenworld Newbie
    In mine it is the ejector seat. Just make sure the roof is down first.
  17. copenworld
    Auckland, NZ
    I must get one of those fitted as well, it could come in very useful :D
  18. CA49000
    CA49000 Copenworld Member
    Cape Town, South Africa
    '06 Daihatsu Copen (Daily)
    Also from South Africa. The copen that i have also has the blanked out switch covers. After thoroughly inspecting the seats now, the wires lead into the top and bottom of the seats but i cant seem to feel or see any heating elements. How would I fit the heater panels to the bottom, because the top part you can unzip and insert the panel, theres space for that.
  19. Scareysue
    Scareysue Copenworld Member
    North West
    Copen Vivid
    Nope, not just with leather seats. Also came as standard in the Vivid. Toasty :D
  20. Scareysue
    North West
    Copen Vivid
    I'll try... If I remember. I'm hard of thinking today.:(
