Timing Chain?
Discussion in 'Problems, Fixes, Tips...' started by Neil, Aug 8, 2013.
  1. Neil
    Neil Copenworld Newbie
    2003 Copen
    Does a timing chain need changing at the same intervals as a timing belt? eg every 100ks
    I am a carpenter so please excuse my totally useless mechanical knowledge.
    Cheers Neil
  2. dsb
    I think I read that the use of a chain makes it unnecessary to change as you do with a belt -but then what do I know? - I wouldn't have a clue what to do under my bonnet.
  3. Adam K
    The Daihatsu service manual for the 659 turbo doesn't specify any intervals for changing the timing chain.
  4. Neil
    2003 Copen
    Thank you Adam K and DSB that was really helpful. This is a great forum. Cheers
  5. Number6
    Timing chains will, generally, outlive the engine.
    The only time you would normally replace the chain is if it is squeaking - evne then, a lot of grease will do the job.
