suns out no hood
Discussion in 'Problems, Fixes, Tips...' started by ian, Apr 24, 2013.
  1. ian
    ian Copenworld Newbie
    billericary
    one
    Hi can anyone help red light for hood inside flashes when i push up on button
    for hood . Also makes a buzzing noise when i drive along. the boot will open from inside ok in the winter i had alot of water in the boot because the top seal is split at the top .
  2. dwayner
    dwayner Copenworld Regular
    Mornington Peninsula
    A 2005 copen and a
    Camry Sportivo
    dwayner
    I had this happen too - almost exactly.
    when the roof was put back on after a warm day, or on unlevel ground, it wouldnt quiet close properly and the little sensor on the part on the roof clip, would not connect. i would hit a bump in the road, and it would beep a few times, and also the light would flash red on the button that operates the roof.
    It comes and goes depending on those two things.
  3. Adam K
    Get it to a garage. Only sure quick way to sort the problem.
    Trying to figure out the problem for the home remedy is very difficult.
    It could be a failed sensor, miss-alignment of the panels, dodgy battery or the ECU could be playing up due to the large amount of water that got in.
    I'm sure I read recently someone's thread with the same issue.
