/ Register
Speedometer stopped working
Discussion in 'General Chat' started by David Berry, Nov 21, 2022.
  1. David Berry
    David Berry Copenworld Member
    Cyprus
    Copen 0.7 2002
    Hi, It appears that my 2002 Copen has an intermittent speedometer fault. It works and then, very very occasionally, it doesn't. Then it works again :)
    Does the speedometer get its input from an electrical or mechanical source? I have looked through the service manual but I can't spot it anywhere.
  2. Rex
    The speedo uses electrical pulses. I remember some years ago finding the cable using the circuit diagram, so I could connect it to a pioneer stereo (to give automatic volume adjustment).
    Rex
  3. David Berry
    Cyprus
    Copen 0.7 2002
    Hi Rex,
    Thanks! That narrows it down a lot. I can ask the garage to now check the electricals as it seems to be so very intermittent. I go back to the 1970s when the speedo used a real cable going into the front wheels and then, later, into the gearbox :)
