Hi all, My copen has stopped its roof action during its process. Guessing if I had to shut down battery to clean the ECU ? Can it be a fuse problem? Thanks by advance, JL
Hello Could there be any water in the boot that has got into the ECU? If there is and you can still access it I suggest you photograph it to proove that this was the cause of the damage. It could just be the fuse. Do your windows work, and does the little red light still flash?
Hi all! Probem was solved I tested the fuse and were OK. Yes, I had a little red light and windows worked. So... I had opened central glove box and and hatch at the bottom. Then I pulled on the little string to throttle roof engine, then putted the string in its initial position. It permits me to close properly the roof. So, I disconnected battery and connected back to clean the ECU. And... it works Thanks for your help and hope it can hepl too
@Audrey Sollis One post is enough for your roof problem. By continually posting on every available thread, you’re unlikely to endear yourself to the generally helpful people on this forum.
The roof wont go down if the red light is on. All the windows have to go down for the roof to work. You may need to reset the Roof ECU?
