Roof ECU
Discussion in 'Problems, Fixes, Tips...' started by gary cad, Sep 4, 2014.
  1. gary cad
    gary cad Copenworld Newbie
    Kent
    Yes Copen + Honda CRV
    It seems like a common problem. The boot seal has started to let water in and even though I have dried it out from the early heavy rain we experianced this year it must have got in to the ECU. Has any one know of any contact to enable me to get hold of a replacement.
  2. Klausanta
    Klausanta Copenworld Member
    Surrey
    Renault Megane
  3. gary cad
    Kent
    Klaus
    The hydraulics are working , can you tell me what caused your roof problem
  4. Klausanta
    Surrey
    Renault Megane
    Hi
    Mine was a combination of faulty sensors on the left hand side assembly and a problem with the boot catch.
    What is actually the fault/problem with your roof/boot?
    What is the roof indicator light doing and when?
    KS
  5. superspat
    superspat Copenworld Regular
    borunemouth
    ford cmax
    daihatsu copen
    run a flash test as it will pin point were your problem is, there are a number of senors and micro switches that all need to work for the roof to work
    there is also a window ecu that talks to the roof ecu that needs to be working before the roof works
    if you down load the manual from here
    https://www.copenworld.com/index.php?pageid=directory
    and work your way through it, i would personally run a flash test of the ecu as its the quickest way to narrow down your search
  6. gary cad
    Kent
    Thanks for the help guys. I will look to try testing this weekend,
    The roof indicator light comes on when uncliping the roof catches and thats as far as it gets , I have managed to open it via the hydraulics
  7. superspat
    borunemouth
    ford cmax
    daihatsu copen
    Do the windows go down? Let us know the results of the flash test
