Replacement Bulbs
Discussion in 'Problems, Fixes, Tips...' started by Klausanta, Nov 14, 2013.
  1. Klausanta
    Klausanta Copenworld Member
    Surrey
    Renault Megane
    Hi All
    Copen Turbo 2004
    Is there a list of standard replacement bulb tye/part numbers available anywhere here?
    And, are the headlight/dipped headlight bulbs easy to change/replace?
    Finally, I keep seeing upgrade kits for the front that give much more light but are very expensive. Has anybody upgraded on Copenworld to something different?
    Many thanks
    KS
    Here's a bulb list.
    http://my-car-bulbs.co.uk/daihatsu-copen-2003-
    These are the rear indicator bulbs:
    http://www.ebay.co.uk/itm/2-x-585-3...Make:Daihatsu|Model:Copen&hash=item5d43038456
    You need to remove part of the inner wheel liner away to get access behind the wing to see the rear of the head light.
    http://www.geocities.jp/nishikawananami/copenhid7500.htm
    This one shows how to get behind the wheel arch liner:
    http://www.geocities.jp/nishikawananami/copenfow.htm
    Not changed to high intensity bulbs myself. Just changed all my indicator bulbs to chrome ones.
    See Section J1 of the 9842 - Chassis manual for more information on how to get to bulbs.
    Couldn't find anything in the manuals that actual specifies the type of bulbs, only the wattage specification.
  3. Number6
    Chrome indicators? Do they flash orange or white? We're required by law to have orange ones, otherwise you won't pass the Irish MOT and the police can give you a ticket.
  5. Klausanta
    Surrey
    Renault Megane
    Many thanks Adam greatly appreciated
    KS
    PS: I hate changing bulbs more that any other car related task!
  6. Rex
    I found it was not easy to change the headlight bulbs, even if you remove the wheel!
    You have to do just by touch. I managed to drop a bulb inside the headlight cluster and never found it! Must be still in there rattling around in there somewhere. :think:
  7. alz2605
    alz2605 Copenworld Regular
    Ceredigion
    VW Golf TDi
    Found the front chrome indicator bulbs but Google is failing to find the rear ones for me. Either that or the 5th double whiskey is impairing my typing!
    Any chance of a link Adam?
  8. tictac
    tictac Copenworld Member
    Melbourne, Australia
    Copen 2004
    Prius 2006
    I replaced my low beam bulbs just last weekend, with upgraded Osram Nightbreakers from powerbulbs (UK site). Bulbs are fairly standard fitment, the low beam are H1 type. As has been described, it's not easy access so you have to be committed to want to change the bulbs, but after you take off the wheel and undo & peel back the inner guard you can get to the bulbs and remove/replace by 'feel'. I also used an inspection mirror and a small torch to see which way around the old bulb was before I took it out (they fit one way).
    I have put upgraded bulbs like this into quite a few cars and I highly recommend the improved light output. The bulbs don't last as long - so be ready to replace them again - and if one fails then the other one will likely fail very soon too (within weeks usually), but they are an improvement.
  9. Adam K
  10. alz2605
    Ceredigion
    VW Golf TDi
    Thanks. I ordered a set of front & rear chrome bulbs & they arrived the other day. Just need a dry day off now to fit them.
    What do I need to look for to replace the interior cabin light with an led version?
  11. Adam K
  12. alz2605
    Ceredigion
    VW Golf TDi
  13. Adam K
  14. Number6
    If you want to be super cheap, you can get one of those D-Sport ones from DealExtreme. I had something similar to the D-Sport in the Pajero, and I plan on getting one for the Copen from them.
  15. alz2605
    Ceredigion
    VW Golf TDi
    Got a link? When I did a search on DealExtreme & it comes up with 100's of irrelevant things :mad:
  16. Adam K
    Search for something like led festoon.
  17. Number6
    http://dx.com/p/1-2w-24-led-car-ceiling-dome-white-light-dc-12v-34606
    http://dx.com/p/white-smd-4-5-20-led-cabin-dome-door-glove-box-light-12v-12742
    The main links are http://dx.com/c/car-accessories-799/car-lights-723/car-led-bulbs-712 and http://dx.com/c/car-accessories-799/car-lights-723/car-decoration-lights-702
    Postage is free, but slow. Keep your orders under €21 (in Ireland), and you don't pay VAT or tax.
  18. alz2605
    Ceredigion
    VW Golf TDi
    I've got a set of front & rear chrome indicator bulbs for over a week now but keep putting off the job of changing them over. I'm sure the job of changing the front ones will be straight forward but just need the time to jack up the car & take off the front wheels.
    I'm a bit stumped on how to change the rear ones though. In the chassis manual it says to work up the backside of the rear bumper & there are 2 clips to press to release the light. I can get my hand up the back of the bumper and I can feel the back of the light but can't feel any clips? Am I on the right track? Any tips would be appreciated.
  19. Adam K
  20. alz2605
    Ceredigion
    VW Golf TDi
