Copenistas, As you can see my cooling fan is running when the engine hasn't warmed up. It could be the sensor but i couldn't be that lucky. Probably the head gasket. Mind you, the temperature gauge is rock solid on 90 degrees. Anyone know where I could get a sensor and where it is located on engine ? Ned
Wine or Chocolates ? Your'e a genius. Whats the rational behind running the fan when the A?C is on do you think? Ned
Could it be something to do with the heater core as that blows hot air from the hot coolant into the cabin?
there is something called a condenser which sits right in front of the radiator. It needs to be cooled in order to provide cold air for the AC. Thats why the fan is running
