Hello, I have a problem with my antenna I can not unscrew it! Is it original this kind of antenna because I always saw a large antenna on the copen?
The antenna you have is after market the original is longer and made of black rubber/plastic..i would wrap a cloth round the base of your antenna attach a pair of mole grips and turn anticlockwise..the threaded stud is possibly a little corroded where it screws in to the plastic base.. also try spraying some wd40 in between base and antenna should help free it up...
Super it worked, thank you. When I removed it, the thread was all rusty. Now, I'll see if I capture better because I had trouble with radio stations. Thanks to you ;-)
