/ Register
Opening Cover
Discussion in 'General Chat' started by Frettchebman, Feb 1, 2020.
  1. Frettchebman
    Frettchebman Copenworld Newbie
    Dortmund NRW
    Copen and Berlingo
    Hi,I have just brought a Copen 2004 and I am looking and learning what I can about the lil Beast.
    I see in the handbook that there should be or was a Opening cover as seen on page 2-19 till 2-23 has any one got theirs do? do you use it?
    just interested
  2. AFR0N1
    That cover was an optional extra.
    I don't think many people use it because you have to first remove it from its storage in the boot, then take roof off, then manually put the cover in place.
    And if you want to put the roof up again, you have to manually remove the cover then put roof up before it can go in its bag in the boot.
    My Copen didn't come with it but It sounds like a bit of a hassle so I'm not sure if it is used often by people who have one.
  3. Frettchebman
    Dortmund NRW
    Copen and Berlingo
    Ah ok thanks I have not seen any photos of one fitted :)
  4. AFR0N1
    Here's some pictures I found online.
    The bag that stores it is located at the back of the boot, so accessing it when the roof is down is impossible.
    And when it's in place it locks to the little pegs across the top behind the roll bar.
    This means your Copen needs the mounting points to be able to install and store it, and copens that weren't optioned with this cover don't have those mounting points.
    It does look nice though, but maybe not worth the trouble
    Frettchebman likes this.
  5. Frettchebman
    Dortmund NRW
    Copen and Berlingo
    Thanks for the trouble of looking, but your right looks very good.
  6. rayva
    rayva Copenworld Newbie
    Aus
    2004 Copen
    I'm getting my 2004 Copen, owned since new, back on the road and while investigating in the boot I found this cover for the first time!
    This car never ceases to amaze :)
