How much boost?
Discussion in 'Problems, Fixes, Tips...' started by Liam Bradshaw, Nov 21, 2015.
  1. Liam Bradshaw
    Runcorn, UK
    Copen 659cc turbo
    What's a safe boost level to run in a copen then?
    I've fitted my air/fuel ratio gauge and it's showing that at 0.7 bar of boost (actuator pressure) the copen it running 10.0 afr which is rich as hell!
    I've upped the boost to 0.9bar and it's still running 10.1 afr!!
    At what boost will it actually run properly and in the range of 11-12afr?
  2. stickypinkyfinger
    Buckinghamshire
    Widearch Daihatsu Copen R
    Race tuned Dinli 450 RS
    Suzuki GSXR600
    Hi. I think the reason you are running so rich is because your car may have a FCD unit mapped into it to fool the fuel system. Look near the ECU somewhere and you should see it. I brought the same one and its adjustable to how much fuel it dumps in your engine.
  3. Liam Bradshaw
    Runcorn, UK
    Copen 659cc turbo
    Cheers I'll have a look. Where about is the ecu?
    I'm now running 1.1 bar and it still pulling 10s as the afr
