Hi :-)
Discussion in 'Introductions' started by SarahB, Apr 29, 2014.
  1. SarahB
    SarahB Copenworld Newbie
    South Tyneside
    Copen (2004)
    Just been outside to have a look - its a metal fuel cap cover but seems to be a problem with the catch as it does sit flush if you push it in a couple of mm
    Misfire im fingers crossed is fixed - its done less than 500 mile in 2 year and even then its been on short journeys so im hoping my bottle of injector cleaner and a good drive has done the trick.
    Oil is somewhere under the cover going to take it off tomorrow and investigate it wasn't there when I looked at the car just appeared on the way home :/
  2. DaG
    I thought it might be a a stick over cover and the thickness of the cover made it not sit flush. Like this one off ebay.....
    http://www.ebay.co.uk/itm/CT-RACING...arts_Vehicles_CarParts_SM&hash=item3cd4639699
    The fuel flap is held closed by a spring loaded plunger and you might be able to bend the tag the plunger goes into to make it close a bit tighter.
    Anyway, best of luck with the problems.
  3. Adam K
    Hi SarahB, welcome to Copenworld. I see Trustafox & DAG have been looking after you. :rolleyes:
    Silver Minilites were a genuine accessory option from Daihatsu. They work well on a Black Copen.
    500 miles in 2 years. If it hasn't had a oil change in that period, I'd get that sorted.
    My guess is the oil leak is from the oil filter joint.
