Help Yellow malfunction Light
Discussion in 'Problems, Fixes, Tips...' started by elizabeth_powell, Apr 24, 2013.
  1. elizabeth_powell
    elizabeth_powell Copenworld Newbie
    dorset
    one proud copen owner
    Hi guys
    Just driven the copen home from Asda and a yellow warning light came on. It looks like a tap/pump picture. Have looked in the book and it says it is a malfunction indicator light and to go to the garage. Has anyone any ideas what type of problem this might be. Hopefully not an expensive one.
    Liz:(
  2. DaG
    It could be one of many things that has caused it to come on.
    The car has sensors dotted around it, they are there to warn you if the car isn't operating inside it's correct parameters. If a problem is detected the MIL lights up to warn you but you don't know which of the sensors has triggered the light.
    You need a code reader to find out what the problem is or take it to a garage and they will tell you. The MIL is known to come on and then go off again of its own accord. If it doesnt go out in three or four starts and stops of the engine you should investigate the problem.
    Read this thread, there's a bit of info about code reading and the MIL.
    https://www.copenworld.com/vb3/showthread.php?t=1524
  3. elizabeth_powell
    dorset
    Thanks DaG
    I will see what happens and take it to garage
    Cheers
    Liz :)
  4. trustafox
    has it had a service in not a long time? but best get an OBD reader on it.
  5. DaG
    If the car is overdue a service it might be worth having it serviced. Something as simple as a faulty spark plug can bring the light on.
  6. DaG
    Did you buy a reader? I know your problem went away but they are worth having in case of a future problem.
  7. trustafox
    I'm hanging my serious nose over a couple. I've been spending on a few other things at present and as its not a pressing purchase it can wait. But I a keep for a toy to play with.
  8. DaG
    When I buy a toy to play with its a RC glider. I've got a loft full of them, other RC stuff and magazines. I've just been looking for a small slope soarer on eBay but the wife will not be happy if another large parcel turns up.:D
  9. dwayner
    dwayner Copenworld Regular
    Mornington Peninsula
    A 2005 copen and a
    Camry Sportivo
    dwayner
    when mine came on it was for O2 sensors to be replaced.
  10. elizabeth_powell
    dorset
    I only bought it in Feb and think she had it serviced in October so I think it wont hurt to get it serviced. I work in a college and they have a motor vehicle maintenance DEPT. They said they will put it on the computer for me they will do service as well just need to buy the bits for it to be done. Think there is a post with what to buy for a service on here somewhere.
    Cheers Guys
    Liz:)
  11. DaG
    If it was serviced last October it is unlikely to be a spark plug causing the problem. The turbo engined Copen needs regular oil changes but not plug changes so I don't think servicing it will put the light out.
    Get your college friends to hook it up and read the code or codes that have caused the fault. Then buy whatever is needed from a motor factors or accessory shop. Have them change the oil at the same time if it hasnt been changed since October.
