Hi been fixing a copen 660 for a friend, broke a valve and garage repairs were sky-high so I offered to help, now after putting everything back together I've come to a couple of problems, first can't find where this plug use to go, also odometer in cluster is not lighting up, and fuel pump not working, does this car come with a factory immobiliser?, car opens and closes from fob everything else in the cluster lights up, just not the odometer.
First problem solved, car is up and running was only a fuse after all, all I got to do now is figure out where to plug this wire ?
Are you getting a check engine light with the cable unplugged? That might give you an idea of what the cable is, and where it belongs according to the service manual.
You can download the wiring diagram form under the Directory Tab at the top of the forum. Have tried to see if you have access yet?
Is the oil pressure sensor, does anyone here know where is it located?. All sorted now Thanks for your help
I had exactly the same issue. I know it goes right round the front of the block and is cable tied to the bottom of the dipstick but cant remember after that. Will think on it. Also after replacing a burnt out valve
