Help! Went to do a full service on the copen today! And what a nightmare, can't get oil filter off, can't remove wheels and the last garage who worked on shouldn't be in business! They fitted new front brake hoses and one end is missing a clip so its not secure, the pipe it's connected to has been spun and is rubbing on abs wire, the middle of hose isn't fixed to the strut, and the hose has been over tightened and has squashed the copper washer and is leaking. And the other front side is the same! What make are the front brakes because i need the bolt and washer which bolts the hose on?
