handbrake cable adjuster
Discussion in 'General Chat' started by chris poulter, Aug 22, 2017.
  1. chris poulter
    chris poulter Copenworld Newbie
    cornwall
    copen 1298
    hi could someone please tell where the handbrake cable adjuster is located thanks chris
  2. welz
    if you send give me a email adresse , i can send you a pdf with photos in german to handle it.;)
  3. chris poulter
    cornwall
    copen 1298
  4. chris poulter
    cornwall
    copen 1298
  5. welz
    send;)
  6. Number6
    From memory:
    The off the centre console, it's held in with a few bolts (some are hidden)
    There's a 10mm nut that you tighten in order to make the handbrake cable tight / taught.
  7. boyo
    boyo Copenworld Newbie
    crewe
    dasihatsu copen
    Adjust brake shoes before adjusting cable
  8. Number6
    The shoes should be self-adjusting
  9. Salieri
    I took apart half of my car yesterday and as Number6 said, remove the center console (its easy, 4 screws on the side, 2 or 3 on top behind plastic covers. You can find the adjuster very easily then.
    Not too sure about the brake shoes though. Ususally they should self adjust, but it's never a bad idea to double check :D
  10. boyo
    crewe
    dasihatsu copen
    If you only adjust cable your shoes will not sit correctly on the cylinders and be out of adjustment. Take my advice and adjust brake shoes manually first adr then if needed adjust cable to suit.I have very rarely had to adjust hand brake cables in the 40 years I have been in the motor trade Hope this helps
  11. Salieri
    What if the cable itself got slack? That does not have anything to do with the brake shoes, does it?
    Anyway, thank you for the explanation :D
  12. welz
    @boyo you live in crewe and your car is not a bentley?:think::wondering:
  13. boyo
    crewe
    dasihatsu copen
    That is my second car a mulsanne
    welz likes this.
  14. welz
