Getting a new key cut
Discussion in 'Problems, Fixes, Tips...' started by Tony, Mar 23, 2018.
  1. Tony
    Tony Copenworld Member
    Salisbury
    Yellow Juke Tekna & 2006 silver Copen.
    Hi guys,
    Day 7 of my Copen ownership and I've driven it for only the second time. I can't stop smiling when I'm behind the wheel.
    So, I read a thread on here and went to Timpsons on Monday and got a key programmed and cut. It opened the door and that was it. Next day I got a second one cut and exactly the same thing. Door opens, but doesn't lock and car won't start. Took it to a second Timpsons that I could park outside and, in the end, they cut three further keys. Key 4 opened and locked the car and started once. Only once. He took it back to 'refine' it but in the end it didn't work. Key 5 just opened the door and then they gave up. They think their keys are a fraction too short. Your thoughts would be appreciated. Tony
  2. Vin Petrol
    Mine works fine from Timpsons, I hadn't tried it in the door but I just went out and made sure.
    In case they're getting the wrong blank mine is branded JMA Spain on one side and on the other marked DAI-1.P1
    If they've changed suppliers or something and don't have the same key blanks anymore, you could buy your own blank key and get it cut and programmed.
    Well, cut, did you keep one of the faulty keys? The actual chip is probably fine since it seems to be a mechanical problem.
    Tony likes this.
  3. BarnsleyRob
    Can you post a picture of your original key and any associated fobs. You may have a secondary Cobra unit fitted.
    Tony likes this.
  4. Tony
    Salisbury
    Cheers Vin. They did let me keep one of the keys so I'll check it when I get home on Sunday.
  5. Tony
    Salisbury
    Many thanks for the reply. I'll post the picture on Sunday.
  6. Tony
    Salisbury
    So here's my key and two of the five that were cut .I'm returning one for a refund and they let me keep one that unlocks the door but doesn't do anything else. Timpsons said they would order an original Daihatsu key and ring me but I don't think that's going to be too easy to do. Any thoughts guys? 20180325_192024.jpg
  7. Salieri
    Why not get one at the dealership? Expensive, I know, but less hassle :D
  8. Tony
    Salisbury
    Thanks for replying Salieri. I didn't realise the old dealerships still did them. My nearest is a fair trek away in Surrey but may have to give them a ring at some point.
  9. Vin Petrol
    Are those JMA keys marked DAI-1.P1 on the other side Tony as my working copy is? There are what I found listed as the correct replacements from various makes:-
    • Silca - DH4RT4
    • Keyline - DAI1STK3
    • JMA - TP07DAI-1.P1
    • Curtis - 881528
    The Surrey dealership might be willing to order (if they don't have it in stock) and mail you the blank if you ask, rather than driving there.
    Tony likes this.
  10. Tony
    Salisbury
    Cheers Vin. Yes, one of the JMA keys does have that reference. Thanks for the info.
  11. BarnsleyRob
    I’m not sure if this will move you along much but try unlocking the car with the remote key fob and then try to start the car with your best Timpsons key within 10 seconds. It may be the immobiliser is linked to the fob rather than they key (which is how mine works).
  12. Tony
    Salisbury
    Cheers. I'll give it a try at the weekend.
