Upon completely removing my N/S/F arch liner (in order to inspect sill end cap) it became obvious that the bottom three rearward retaining clips appear to be "single use only". Has any body a fix/tip etc for replacement or re-use. Link to generic clips that will fit ? Thanks in advance, Moby
Hi. Had the same issue and found these on AliExpress. Haven't received them yet but seems to be exactly the same clips. https://www.aliexpress.com/item/400....order_list.order_list_main.11.1d831802QVw0BS
Have you found any? I have new ones after a minor incidence which were never used after repair. I also have the interior plastic left wing guard, also new. Let me know !!
Only just spotted this reply, apologies. I've plumped for some AliExpress multiples which contain similar retaining clips. Many thanks for your offer regardless. Furthermore should my "copies" prove insufficient I may be interested ;-)
