Door locking
Discussion in 'Problems, Fixes, Tips...' started by Pagodane, Apr 26, 2014.
  1. Pagodane
    Pagodane Copenworld Newbie
    suffolk
    Daihatsu Copen 0.66 TURBO CONVERTIBLE
    Mercedes A150
    Hi
    just acquired my copen to discover the drivers side door does not lock manually I have 2 grey keys and a remote both keys lock and unlock the passemger side and the remote locks both doors the lock works from inside as well I am assuming there is something wrong with the door lock internally and not electrical ?
  2. DaG
    Does the key turn the lock or does it go in but you can't turn the key?
    If the key turns but the door doesn't unlock then it is likely something has come adrift inside the door.
    If the key doesn't turn the lock then the lock is faulty or has been changed in the past for a a replacement the key doesn't fit.
  3. trustafox
    idea 2: or seized up and needs lubricating/freeing
  4. DaG
    Yes if the key won't turn the lock flood the lock with freeing oil. I was going to say WD40 but don't like to advertise.
  5. trustafox
    well you just did! :rolleyes:
  6. DaG
    Really?:D
    It's called irony.
  7. trustafox
    Oh, has it changed its name? :think:
  8. Pagodane
    suffolk
    Mercedes A150
    Thanks and yes the key turns freely both ways so im guessing somethings adrift inside
  9. DaG
    Yes it will be a something disconnected. You'll have to take the door panel off and take a look inside, sounds an easy fix.
  10. Natalie
    Natalie Copenworld Newbie
    Australia
    I have a similar problem, but my problem is that the remote locks/unlocks the passenger door only. not the drivers door. i can open both doors manually.
    any ideas?
