Daytime Running Lights
Discussion in 'General Chat' started by Bemused, Jul 31, 2016.
  1. Bemused
    Bemused Copenworld Regular
    Stoke-on-Trentishoe
  2. shane
    shane Copenworld Regular
    Devon
    Daihatsu Copen 0.66
    I'm sure I read somewhere in here about a mod to make the fog lights work with the main lights off. Would that not be a better solution?
  3. Bemused
    Stoke-on-Trentishoe
    I could easily make the fog lights stand alone but its not legal to drive with fog lights on unless its errm... foggy
  4. lucullus
    lucullus Copenworld Newbie
    Copen 1.3 LHD
    Hello
    IMHO The first document is correct. I've seen similar regulations in other countries.
    I can provide an idea, but no solution:
    Get flexible LED ones and either bend the into the lower half of the headlamp (like an U) or into the small seam just below
    the foglights.
    Furthermore the place beyond the bonnet and above the grill is for reserved moving red lights only :) (see picture)
    Regards
  5. Bemused
    Stoke-on-Trentishoe
    The first document is UK government and I suspect its EC based.
    The question is weither the first document is applicable for retrofitting to pre DRL legislation cars.
    The second document is a freedom of information request to UK Department of transport about retrofitting to pre DRL cars.
    And what the hell is that car with night rider lights, is it yours?
  6. JulesAtCumbria
    Cumbria, UK
    2009 (59) Copen
    Well, Bemused, Neville had his fitted last year and flew through his MOT just fine - no mention of a problem. They're mounted on that bracket that runs behind the grille (I thought it was metal but turns out to be plastic!). Visibility Improvement >10!
    Brad likes this.
  7. Bemused
    Stoke-on-Trentishoe
    Neville looks happy with them and they sure are bright.
    Which did you fit?
  8. JanesAddiction
    W Mids
    1.3 Copen
    Ours were placed behind the grille too, we used led's with a brightness of 6k really really bright head on.
    Brad likes this.
  9. JulesAtCumbria
    Cumbria, UK
    2009 (59) Copen
    As you say, they are bright and to be honest there's little point in fixing cheap ones that don't do what you want them to do, so I went for a set of Ring BRL0397 lights (about £50 on ebay last year). Let us know how you get on.
  10. Bemused
    Stoke-on-Trentishoe
  11. Neil50
    Neil50 Copenworld Regular
    Saltash, Cornwall
    Audi A2
    I see that most cars are now having day running lights as standard or aftermarket. Why??
    Being ex-miltary i always drive with headlights on, therby not needing day running lights.
    The other issue is that i have passed many people as it goes dark and they have their day running lights on, which are so bright they forget to turn on their normal lights which inlcudes the REAR lights!!
  12. Bemused
    Stoke-on-Trentishoe
    As I understand it, and it's all new to me.
    DRL are now mandatory on European cars, DRLs give a better spread of light for daytime use compared to the head lamps beam pattern, DRL light pattern is designed to be noticed during daylight, head lamps are designed for driver vission at night, DRLs have statistical evidence of reducing accidents by 10%, DRLs are for daytime use only, if used at night time they must be dimmed circa 50%.
    There are specific positioning dimensions for DRLs on new vehicles.
    These dimensions may not necessarily apply to retorfit on cars pre DRL requirement (unsure on this one)
    There thats all I know on the subject.
  13. Neil50
    Saltash, Cornwall
    Audi A2
    Thanks, i have just looked at the info on the AA Website. The main fall down with this, is that people are not turning on their normal lights when it gets dark and therefore they have no rear lights on. This also happens in poor visibility and heavy rain.
    I have seen some very close misses when vehciles have nearly driven into the back of one with no rear lights on, but with day running lights turned on at the front.
  14. Bemused
    Stoke-on-Trentishoe
    Next up will be legislation for automatic headlights to stop fools driving in the dark with just DRLs :)
  15. Neil50
    Saltash, Cornwall
    Audi A2
    I think that some people just dont pay attention when driving. I also ride a motorbike and my lights are always on!!
    A lot of new cars have automatic lights and wipers, it shouldnt be hard to automatically turn the lights on when the wipers activate or the light sensor senes dark/dusk. (turning off DRL at the same time)
  16. Neil50
    Saltash, Cornwall
    Audi A2
    I think i have taken it slightly off track as this is supposed to be for mods.
    I wonder if i can get spotlights to mount on the top of the windscreen frame and some neon for below so it looks like a spaceship coming at you (a small spaceship mind you, more like an escape pod)
  17. Bemused
    Stoke-on-Trentishoe
    On the whole I feel no need for DRLs on our two main cars but we have had a few cases where other drivers did not see our Copen when they should have, hence my thoughts on DRLs, maybe it's coincidence or maybe a black Copen.
  18. Neil50
    Saltash, Cornwall
    Audi A2
    Waspy is bright yellow ( same as my motorbike) so people SHOULD be able to see him, but it could be good as "belt and braces". How easy are they to wire in?
  19. Bemused
    Stoke-on-Trentishoe
    The ring mentioned above and many others are very easy to wire up.
    Just look on the ring website, they have there own control module and just three wires, +/-/side light connection. Must sense engine running by alternator pulses I assume.
    BRL0397 | Aurora Daytime Running Lamps | Accessory Lighting
  20. Bemused
    Stoke-on-Trentishoe
    I like the round, I like the rectangular, I like the round. Bugger, too many choices for a simple blokes head.
    JanesAddiction likes this.
