Daft Questions !
Discussion in 'Introductions' started by Mark A. O'Neill, Jun 30, 2017.
  1. Mark A. O'Neill
    Mark A. O'Neill Copenworld Newbie
    Stourbridge
    2008 Daihatsu Copen 1298cc, 1956 Standard Super Ten, 1991 Nissan Figaro
    Hi All
    I just today bought a Copen 1298. Amazing car!
    Could you advise what the most common issues are in your experience. Thing I should look out for when I spend time in the garage going over it with a tooth comb.
    Cheers Mark
  2. Chrismadeley
    Canterbury, Kent, UK
    Copen Vivid Special Edition
    Check the battery is in good condition or even replace it. I had repeated random multiple misfire but a new battery solved the problem
    Mark A. O'Neill likes this.
  3. Mark A. O'Neill
    Stourbridge
    I think it's recently been changed but I will check it. Thanks
  4. Salieri
    Welcome!
    Can confirm battery, its only 35Ah (weak as)
    Rust is an issue, it can be found virtually anywhere (except bonnet, roof and boot lid), but it's mostly well hidden (boot floor under the carpet, undercarriage etc.)
    The engine will not cause much trouble if you give it some maintenance every now and then (5w30 or 0w40 are recommended, spark plugs NGK or Denso)
    Pretty reliable :D
  5. welz
    and take a look front brakes inside..often rusty nogo for mot..:(
  6. Mark A. O'Neill
    Stourbridge
    It's had an advisory for the front discs so that on my agenda to sort out soon
    There is rust on the bonnet but nowhere else I've seen. Yet!
    Engine seems good too so far
    Some crud under arches but I don't think it's gone through yet so that's to be cleaned checked and proofed too
    Might look to see if I can put a better battery on before winter
    M
  7. Salieri
    Its not rust on the bonnet, its aluminum corrosion, probably caused by a bad paintjob or stone chips
    German made ATE discs are factory painted and rust less, I do recommend them. Still there is a chance the inner side of the disc will rust because breaking pressure is not strong enough to remove the light surface rust which occurs naturally
  8. Mark A. O'Neill
    Stourbridge
    Mmmm. Any idea how easy it is to get a new bonnet? just an Idea. I'm guessing Aluminium is not tat easy to repair due to low melt temperatures and stretching potential.
    M
