Bought Copen Model 2004 today..
Discussion in 'Introductions' started by welz, Jun 8, 2015.
  1. welz
    Hallo my Name is Kai from Germany.
    I'm also the owner of a green 2004 Copen since today.
    Unfortunately, I lack the operating instructions.:(
    which oil and lot of it I need for the engine?
    How often it should be changed?
    greets from Leverkusen, Germany
  2. dsb
    every 3000 miles. and the filter every 6000.
    think you'll find the oil type info here in a few posts.
  3. scooty
    Hi Kai,
    recommended oil for the 660cc engine is 5W30
    2.5l without oil filter change
    2.8l with oil filter change (every 2nd oil change)
    dsb is right with oil changes every 5.000 km, in addition Daihatsu states "OR every half year".
  4. welz
    thanks a lot..must it full syntetic oel?
    My new car has an new turbo loader.old was broken..
    greets Kai
  5. welz
    Hello,,
    Is it possible to use E10 patrol?
    greets Kai
  6. Number6
    No, it doesn't need to be fully synthetic. I believe the API rating is SG or higher, which every new oil should support.
    Since you are just after replacing the turbo, I'd recommend going for a more expensive oil such as Castrol's fully synthetic Magnatec to ensure the turbo lasts as long as it can
  7. welz
    Thanks all lot Numer6..at next change I will try it..
    Kai
    what about E10 fuel..can I use it?
  8. scooty
