0.7 wing mirror replacement
Discussion in 'Problems, Fixes, Tips...' started by piccolaninfa, Mar 24, 2014.
  1. piccolaninfa
    piccolaninfa Copenworld Newbie
    Hello fellow Copen lovers :) Quick question - does 0.7 model wing mirrors are the same as newer 1.3? Mine (2004) one got smashed :-(( and need to replace it, have found few on ebay but they do not specify which model it will fit so my guess it fits them all... Any ideas? Is it hard to fit them?
    Many thanks!
  2. piccolaninfa
    No one knows? :,(
  3. scooty
    Mirrors are the same on both models, but no idea about fitting.
  4. piccolaninfa
    Ok thanks a million :) need to find out
  5. Adam K
    i believe they are pretty simple to swap over. The tricky part is taking the little plastic cover off, hiding the two screws. Once that off it's a case of undoing the two screws & disconnecting the harness.
  6. piccolaninfa
    Thanks Adam I will try :)
  7. piccolaninfa
    Hi i i,
    I tried to unscrew the mirror in the driver side but after doing it and try to remove it I got stocked,the cable is going inside the door ....mmm...i m wondering if there is any way to get inside and disconnect the cable so I can place the new mirror, does anyone knows? I really need help, can't find nothing in Internet, if I manage to change it I will make a video and put it in YouTube for others like me ;)
  8. DaG
    Is there not anything about doing this in the workshop manual?
  9. piccolaninfa
    In mot in the user manual,I a that another manual? The one I have is in German :/ the girl that sold it to me bought it from germany there is no chance I can understard, where can I find this manual? In English?
  10. Adam K
  11. piccolaninfa
    Thanks a million ;)
  12. Ewoud van Munster
    Ewoud van Munster Copenworld Newbie
    Delft (netherlands
    Daihatsu copen 0.7
    Hello fellow copen owners:)
    i have a small question about this thread,
    you said:
    but how is that excactly done!?
    i can see a little notch on the bottem side, but have no idea how to get if off without breaking it,
    could anyone give me a little advice in this?
    thanks in advance;)
  13. ady_bod
    ady_bod Copenworld Newbie
    Hi guys,
    My side glass mirror is broken. Is there a way to replace just the glass without replacing the full mirror arm?
  14. Shahram Azimi Nobar
    Egham
    Hi Ady_bod,
    Hope all is good with you. Looks like you're on the hunt for side mirror part numbers for your Daihatsu Copen - good news, I've got the info you need!
    For the left side mirror, you're looking at part number 87947-97202, and for the right one, it's 87917-97202. Pretty straightforward, right?
    Now, when it comes to buying these parts, I've had a lot of luck with this site: IMPEX JAPAN — online new genuine spare parts shop.
    Another option, though, is to give your nearest Daihatsu Copen ex-dealer a shout. They might have these parts on hand or at least be able to order them for you. Check out Daihatsu to find your closest one.
    Anyway, hope this helps!
    Cheers!
    ady_bod and Brad like this.
  15. ady_bod
    Hi Shahram,
    Thank you for the parts numbers. From what I can see these are the mirror- glass only. Any idea if these can be replaced or needs a full mirror body with the glass.
  16. Shahram Azimi Nobar
    Egham
    Hi Ady, I wish I knew the answer. I would suggest asking an ex-Daihatsu dealer or a professional body shop repair. They should be able to replace the mirror.
