what's this new loud whistling noise?
Discussion in 'Problems, Fixes, Tips...' started by dsb, Sep 5, 2014.
  1. dsb
    yesterday morning got in the car to go to work and thought I heard a police siren behind me.
    then I realised - it's my copen.
    when I put my foot down, I'm getting a high pitched whistling that rises in pitch as my speed rises - never had that before.
    have a horrible feeling it could be the turbo - and a sign that it's going.
    anyone experienced this? - have another explanation?
  2. superspat
    superspat Copenworld Regular
    borunemouth
    ford cmax
    daihatsu copen
    have you checked the air filter hoses are all connectded and that nothing has come lose
    also worth checking the intercooler pipe work and all the pipe work
    it dose sound like it could be turbo, but could be pipe has come lose causing you to hear the turbo compressor spinning
    dose it boost ok still or are you down on on power? do it make the noise when you are going fast but not on the throttle?
  3. dsb
    Only seems to be when on the throttle. I'm due to change the air filter tomorrow so fingers crossed it's just a bit loose from where I recently undid it
  4. dsb
    Popped it into a garage today and they suspect that it's just some loose piping to the turbo - fingers crossed that is the issue as it did appear out of nowhere overnight. They also pointed out a ticking noise when idling so hopefully that will be dealt with
  5. dsb
    I now have a knocking noise to go with the other noises :(
    I have a bad feeling about this.......
  6. superspat
    borunemouth
    ford cmax
    daihatsu copen
    The ticking could just the injectors clicking/ticking away,we're is the knocking coming from, could be what ever has come lose vibrating against side of engine or chassis, think positive and hopefully it's nothing serious
