what grade of oils???
Discussion in 'Problems, Fixes, Tips...' started by princess, Aug 27, 2011.
  1. princess
    princess Copenworld Regular
    notts
    hello everyone
    Hubby is planning on changing engine oil and gearbox oil on bank holiday monday. Can anyone suggest what grades he needs to get.
    Many thanks
    princess:)
    Hi Princess,
    Quoted from the Information manual page B5-3
    For the engine oil you need;
    5W-30 (API grade SG or higher). I used Magnatec 5W-30
    If your changing the oil filter too, you need 2.7l.
    If your only changing the oil you need 2.5l.
    Quoted from the service manual page F2-1
    Gearbox oil;
    Transmission gear oil SAE75W{{-}}90 or SAE75W{{-}}85 or SAE75W{{-}}80 (API grade GL3 or GL4) -90 or SAE75W-85 or SAE75W-80 (API grade GL3 or GL4)
    Total capacity approx. 2.1 - 2.25l
  3. princess
    notts
    Thanks adam i will pass the info on to hubby:D:D
    How did the oil change go?
  5. princess
    notts
    oil change went ok, but he says he needs a filter spanner because its in such an EASY place to get too!!!!! any ideas adam on what he needs?
  6. Adam K
