wet day
Discussion in 'General Chat' started by bluebird32, Mar 4, 2015.
  1. bluebird32
    bluebird32 Copenworld Newbie
    london
    daihatsu copen turbo
    Hi al capon owners just sold my cappuccino for a more refine drive. I don’t normally drive me cappo in rain but Thursday rain all day had to put me wets on the dam cappo was leaking through the door the roof I would have been better of taking off the roof . Driving m25 felt like driving under water anyway got the copen 2 previous owners both o.c.d. One problem did find with car in boot pool of water no fish? even though car has been garaged all the time any one got idea what’s cause. Thank you for reading
  2. Binz
    Binz Copenworld Regular
    North Hampshire
    Cause of wet boot is normally the seal around the bootlid brake light. Options are replace the seal, or use a sealant.
  3. bluebird32
    london
    water in boot
    Thankyou binz i will try that
  4. Your Majesty
    West Midlands
    Copen, no other car.
    No water in my boot any more
    My Brake light doesn't leak (tested with watering can experiments last year) but boot gets wet if I park it facing uphill - took ages to work this out :(
    Parking this year facing downhill and no water ingress at all :) I think the water gets in at the top corners of the boot where it meets the bottom of the window.
  5. dsb
    keep in mind that once it's in the boot it can creep into the main car - behind the seats by osmosis.
    had to put paper behind the seats with bricks on for a few weeks before I managed to totally dry mine out.
  6. magsjm
    magsjm Copenworld Member
    CAMBRIDGE
    COPEN & KIA SORENTO
    Hi, I had the same problem with mine, I replaced the brake light with a clear one which came with a new seal,I thought this had cured it but now and then I still find water under the carpet, I have also noticed heavy condensation on the underside of the boot lid usually after a cold damp night, I will fit insulation to the underside of the lid and see if this helps.
    I had a similar problem with an aluminium roof on my shed once and fitting insulation prevented any further condensation from forming, so hoping for the same result.
  7. bluebird32
    london
    do you keep your car in garage
  8. magsjm
    CAMBRIDGE
    COPEN & KIA SORENTO
    Mine is kept outside in all weather.
  9. Coolcarbon
    Coolcarbon Copenworld Member
    Scotland or Zummerzet
    Q3
    C4
    BX
  10. bluebird32
    london
    ta
    nice one.; are you into moto gp
  11. ct30
    ct30 Copenworld Newbie
    United Kingdom
    Hello I’m getting the condensation again now the weather is getting colder. What insulation did you get and how did you manage to fit this in? Many thanks
