/ Register
Water Leaking
Discussion in 'Problems, Fixes, Tips...' started by Dickens, Apr 26, 2019.
  1. Dickens
    Dickens Copenworld Newbie
    Hong Kong
    Copen 2007
    Anyone have problem of rain water leaking from the roof + windows connecting point ? I find water soaking wet seat inside the car after a night of heavy rain ! How to fix this problem ?
  2. AFR0N1
    I haven't had that problem, so I might not be of much help. My guess is the rubber seals are going bad :(
  3. BarnsleyRob
    If it’s where the roof joins the windscreen, you can tighten the catches to compress the seal. What condition are the seals in ? You may need to lubricate them.
  4. CoppedEnd
    CoppedEnd Copenworld Newbie
    London
    Copen 0.7 2003 model
    As said, lubricate the seals so they are supple. Also make sure they are clean. Any small bit of dirt can let water run in. One day water may come in. After dropping the windows and raising again, it may be alright.
  5. Dickens
    Hong Kong
    Copen 2007
    I have the same problem, do I need to change the rubber seal ?
  6. BarnsleyRob
    Did you clean the seals and tighten the catches like we told you last year @Dickens ?
