water leakage =/
Discussion in 'General Chat' started by coopenahsiong, May 2, 2014.
  1. coopenahsiong
    coopenahsiong Copenworld Newbie
    dahaistu coopen
    Hiii I am copen noobster here.
    I notice water dripping on the left front side.
    I wonder if this is normal a/c water drip or tge radiator water leak?
  2. DaG
    Sounds like the aircon.
    An ac systems condenser draws moisture out of the air as part of the cooling process. That water has to go somewhere and that is likely what the dripis are you can see.
    Try tracing the drips to make sure it isn't a hose or water pump leak. Or drive the car with the aircon switched off, you should then get no dripping.
  3. Number6
    The radiator water should be coloured. If you have a garage, you can put a number of white paper kitchen cloth underneath the leaking area and see what colour it is - if it's clear, it's probably the A/C.
