Tyre size problem, does 155/60/15
Discussion in 'Problems, Fixes, Tips...' started by Kristian, Dec 6, 2017.
  1. Kristian
    Kristian Copenworld Newbie
    Denmark
    Daihatsu Copen 1.3
    Hi
    Has anyone every run 155/60 tyres on 15'' rims?
    Its getting cold here in Scandinavia and those are the only spec tyres i can get hold off.
    Any advice is much appreciated.
    I have already studied this matter on this site but could not get any of the tyres people have used
  2. welz
    i use 165/60 R14 T on 14 steel rims, never heard that someone had get then on 15 rims -
  3. Kristian
    Denmark
    Daihatsu Copen 1.3
    I thought that 14'' rims would hit the brakes on the front?
    I can't seem to find anywhere in Denmark that does the 165/60:(
  4. welz
    David 48 likes this.
  5. Salieri
    I have 14" rims and they absolutely do not hit anything, so no worries :D
    Uniroyal MS Plus 77 165/60 R14 75T - daekonline.dk
    These are the Uniroyal tyres, they are average quality and made by a subsidiary of Continental
    If you wanted to run 15" rims, you would have to get 165/50 r15 winter tyres, but they seem to be out of production :D
  6. Kristian
    Denmark
    Daihatsu Copen 1.3
    You guys are bloody amazing
    Was going to buy 15'' rims and go for 175/55 continental tyres but your options sound much cheaper
    Thanks a bunch
  7. Salieri
    These are 100% correct, you would need exactly 5x14 ET40 rims with a 4x100 bolt pattern
  8. welz
    @Salieri nice, if time maybe we can go for a beer meet next year..:D
    and could help kristian
  9. Salieri
    Beer in denmark is way too expensive :D
  10. PaulGee
    PaulGee Copenworld Member
    Daihatsu Copen 1.3
    Daihatsu Materia 1.5
    Honda CRV (MkII)
    What pressure do you inflate them to?
    I've just put a set of 165/60 R14 on my Copen and I figure they should be about 31psi but no hard evidence that is the case.
  11. PaulGee
    Daihatsu Copen 1.3
    Honda CRV (MkII)
    I fitted these Alcar KFZ 5645 » Steel Wheels » Oponeo.co.uk
    Wheel size: 5,00Jx14 PCD: 4x100 Offset: 40.00 Central Bore: 54.1
  12. Salieri
    I inflate mine to 2,5 bar, which is 36 psi in medieval terms :D
    ronalddoes likes this.
  13. PaulGee
    Daihatsu Copen 1.3
    Honda CRV (MkII)
    36 psi seems pretty firm, given that the standard 165/50R15 have a psi of 35.
  14. Salieri
    Not at all mate, you can put 10% extra on the recommended tyre pressure and it will benefit you with a better fuel economy. This way you also have a little safety buffer.
    Also, its still a 165 tyre, so pressure should be the same
  15. Philippe
    Philippe Copenworld Newbie
    Belgium
    Has anyone tried 165/60 r15 and know if they fit without issue?
    i want to get continental ts860 for the winter on the original rims. :)
  16. welz
    165/60 doesn`t fit on R15 , only on R14, 165/70 on R13 doesn`t fit because rims would hit the brakes on the front.
