Tap into headlight wiring?
Discussion in 'Problems, Fixes, Tips...' started by DavidM, Jul 23, 2020.
  1. DavidM
    DavidM Copenworld Newbie
    Canada
    2005 L880K
    I need to install Daytime running lights on my copen for inspection purposes. I'm just going to use a simple relay to power the lights but I'm having trouble finding the headlight wiring under the dash. Can anyone point me in the right direction? Wire colour? location?
    thanks
  2. DavidM
    Canada
    2005 L880K
    guess I'll pull the front bumper and try and tap in right at the headlight...
  3. AFR0N1
    In the resources section on this site is a workshop manual and it contains wiring diagrams for everything.
    Anyway, heres the ones I think you need.
  4. Tieak
    Tieak Copenworld Member
    Stirlingshire
    Copen 1.3 2007
    Fiat 500
    Seat Leon
    For what it’s worth, I used a voltage detection switch, which just detected the increased battery voltage when the engine’s on, to control my daylight running lights.
    It made the fitting of the lights fairly straightforward and avoided any changes to the core wiring. They are fairly cheap affairs, I got mine on eBay, perhaps worth a look to see if they are suitable for your requirements.
  5. BarnsleyRob
    As above.
    Plus, if you tap into the headlight, the DRL will only be energised when the headlamps arebturned on which slightly defeats the object.
  6. DavidM
    Canada
    2005 L880K
    Thanks to all. I did pull the front bumper to get to the wiring and completed the DRL install. Now off to inspections :)
  7. BarnsleyRob
    Which circuit did you tap in to ?
  8. DavidM
    Canada
    2005 L880K
    Used a 12v 40amp 4 pin relay. Power from battery, Ign Acc from radio, ground, and power to Red/Pink wire right at left headlight. When ignition is turned on Acc1 power is supplied to headlights via the relay and both headlights (low beam) turn on. Should be ok for passing regulatory inspections.
  9. BarnsleyRob
    Oh okay, you are using the standard lamps as the DRL instead of dedicated LED units. Makes sense as it gets around the issue of dimming LEDs when you use the headlights, although the aftermarket voltage detection units are able to handle that.
