stevie b
Discussion in 'Introductions' started by Steveholden, Aug 23, 2011.
  1. Steveholden
    Steveholden Copenworld Newbie
    hi everyone just collected my new(to me ) copen really love it but wheres the spare? :think:
  2. Scareysue
    Scareysue Copenworld Member
    North West
    Copen Vivid
    It doesn't come with a spare wheel. There should be a tire inflation kit in the boot. Check that the fluid is still in date.
  3. Adam K
    Welcome to the forum Steve. :D
    Scareysue is spot on.
  4. Steveholden
    thank you guys i don't think mine has one, i'll have to get one ;)
  5. Adam K
    In the boot right at the front there is a flat bit. Lift that panel, underneath is the hydraulic stuff & ecu for the roof, also under there should be the jack & tool bag (wheel nut bar, two metal wire handle things can't remember what else). You should also find in a black bag some tyre gunk & an air compressor.
    If it's not there ask the seller where it went.
  6. Greg
    Greg Copenworld Newbie
    Bournemouth
    Copen and Peugeot 407
    My Copen didn't come with a tire inflation kit or any tools, so bought a portable air compressor on ebay.
    You mentioned about gunk. What kind of liquid is it , special glue ?
  7. Scareysue
    North West
    Copen Vivid
    I think Tyre Weld is the technical term :)
  8. Adam K
    You need to look out for a tool kit then. If your roof stops working there are a couple of little wire loop handles that are needed to manually close/open the roof.
  9. Adam K
  10. Greg
    Bournemouth
    Have checked out both but no luck. Will be shopping around ;)
