Sloppy gear change
Discussion in 'Problems, Fixes, Tips...' started by Bleary, May 13, 2019.
  1. Bleary
    Bleary Copenworld Newbie
    Herts
    660cc Copen
    Hi all,
    Changing gears is a bit sloppy, theres almost as much play when in gear as when in neutral...
    It finds gears and stays in gear fine, it's just quite vague and loose.
    Is there anyway to tighten the gearbox/gearstick up a bit?
  2. CoppedEnd
    CoppedEnd Copenworld Newbie
    London
    Copen 0.7 2003 model
    There are usually bushings at various parts of the gear linkage. Just check/replace them.
    Bleary likes this.
  3. Planter
    Planter Copenworld Newbie
    UK
    I have the same sloppyness on my gear linkage. The rear bush at the rear of the gear box near the gear lever has perished.
    Where can I get a new bush? I am struggling to find a parts diagram or supplier.
    Jo Stoneley likes this.
  4. Jo Stoneley
    Jo Stoneley Copenworld Newbie
    Stafford
    Hi there, new to this but I join to find out a answer to this as well. My gear lever is so sloppy but I’ve been told it’s the gear lever linkage anybody with a parts lists to replace the upper linkage please
  5. Salieri
    A few years ago I have made a list of parts to replace the linkage beyond the gear lever, but not sure if it's 100% correct.
    9671119014000 (WASHER)
    9004386105 (BUSHING)
    9004179052 (NUT)
    9004101460 (BOLT)
    AFR0N1, Jawwad and Jo Stoneley like this.
  6. Jawwad
    Jawwad Copenworld Newbie
    Pakistan
    Copen 660
    Thanks for providing the part numbers.
