Seat belts
Discussion in 'Problems, Fixes, Tips...' started by Zippy, Dec 3, 2016.
  1. Zippy
    Zippy Copenworld Newbie
    Southampton
    Copen 1.3. 2008
    Hi
    Has anyone got any tips on making seat belts retract properly?
    Kyungil Chang likes this.
  2. Binz
    Binz Copenworld Regular
    North Hampshire
    search on here for previous discussions. Basic things are replace guides with less restrictive ones, also some have tried coating the belts with (I think) silicone. I also find moving the seat forward an inch will help.
  3. Your Majesty
    West Midlands
    Copen, no other car.
    The optional polished steel belt guides offered by Daihatsu make a difference - because they hold the seat belt higher up nearer the exit point behind the seat. We have these on our Copens and they are a vast improvement over the standard black belt guides. I don't think there is a better solution because of the severe angles that the belt travels around behind the seats but these guides reduce one of the angles and help a lot.
    Not easy to find now, but this dealer still has some...
    Belt guidance | Online-Shop Kiessetz & Schmidt GmbH
  4. jcuyckens
    jcuyckens Copenworld Member
    Belgium
    Volvo XC60 2015
    Toyota Corolla 2004
    Rover 45 V6 2005
    Daihatso Copen 2006
    BMW R850RT & R850R
    Yamaha GTS1000 1993
    Hi,
    two things that worked with my car;
    1) put some degreasing agent on the belt and rol it several times while rubbing it with a cloth. Afterwards put some silicon dashboard spray on the belt, it will slide better.
    2) buy two spoons and mount them like on the pictures, it resolves the friction problem of the leather.
    I believe these are cheap sollutions....:)
    APPLEDjerry and Kyungil Chang like this.
  5. Soc
    Soc Copenworld Regular
    Zippy, try this which does work. The seat belts over time go stiff due to dirt, sweat etc so don't retract as well. Get some Furniture spray such as Mr Sheen and spray it on the seat belt and a cloth and pull the belt out and wipe it generously all over the belt both sides a number of times. That's it! Let me know how you get on.
  6. Zippy
    Southampton
    Copen 1.3. 2008
    Thanks for the replies will try them out at the weekend
  7. Zippy
    Southampton
    Copen 1.3. 2008
    Those look good, thanks for link
  8. Kyungil Chang
    Kyungil Chang Copenworld Newbie
    Seoul South KOREA
    Copen 2007 Ultimate Edition 2
    GLK 2013 Mercedes Benz
    Vespa GTS250is
  9. Kyungil Chang
    Seoul South KOREA
    Vespa GTS250is
    Awesome!! Let me try~ Thanks
  10. scooty
    Two more options:
    Possible fix for Seat belt Guide retraction
    or take a look at the PDF attached, it's in German but you might get the idea by looking at the pics (basically it describes sanding the seatbelt top guide and enlarging the seatbelt-outlet of the plastic panel).
  11. Vmarx
    Vmarx Copenworld Newbie
    poland
    copen 0,7
    I got to box lanes, got under way and I naciaglem spring (in some cars it helps), but no effects (Tylk shortens the belt) so poszerzzylem through-hole on the belt in the plastic seat and it's ok, I greet
  12. freddyzdead
    Gosford, NSW, Australia
    2003 Copen
    Soc is on the right track with this. The main culprit is dirt and sweat ingrained into the belt. To fix this, pull the belt all the way out, put some sort of clamp on it so it can't retract. Make a bowl of very hot water with Morning Fresh or some good quality dishwashing detergent. Soak the belt from top to buckle, rub with terrycloth washer or towel. Repeat once or twice, or until the water stays clear. Allow to dry in the sun. Belt will now retract much better. You'll be surprised at how filthy the water gets. After this, you can try the Mr. Sheen if you like, but there's a possibility it could go gummy over time. Best thing is just a clean belt.
    APPLEDjerry and Gwyn like this.
