Roof warning light
Discussion in 'Problems, Fixes, Tips...' started by PaulGee, Feb 23, 2019.
Tags:
  1. PaulGee
    PaulGee Copenworld Member
    Daihatsu Copen 1.3
    Daihatsu Materia 1.5
    Honda CRV (MkII)
    Spring is here and today was a roof down day for Horace (1.3)
    So the roof open and closes fine, however the roof light stays on when closed, which implies it isn't closed properly but it looks fine to me.
    Now before I took to the forum I did a good search around and watched the YouTube video about diagnosing the flashing roof codes and joining two pins on the OBDII connector and then I went to download codes and diagnostic instructions from the video.... and the web link is missing/broken.
    Does anyone have a copy of the diagnostic instructions and codes or better still any idea on what this issue might be.
    I figure a microswitch somewhere but I've no idea where to look.
    Thanks in advance.
    If the light is still on you should be getting a warning klaxon as soon as you go over 5 km/h
    The microswitches are located where the two clasps connect the roof to the window frame
  3. PaulGee
    Daihatsu Copen 1.3
    Honda CRV (MkII)
    Yep the warning sound did go off as I pulled away last night but I gave the right clasp a thump and the light went out :rofl:
