roof problems
Discussion in 'Problems, Fixes, Tips...' started by daramus22, Dec 26, 2010.
  1. daramus22
    daramus22 Copenworld Newbie
    sometimes when i try to open /close the roof the warning light flashes and nothing happens.
    is this common or does it have a mind of its own?
  2. lammy
    lammy Copenworld Newbie
    Only works when handbrake is on !!! (similar problem I had due to handbrake switch not making) - hope this helps , Lammy.
  3. daramus22
    The hand brake is on,car is in neutral, on flat ground, tried it all but maybe the switch in the handbrake is faulty. where can i get it checked , im in brisbane...
  4. MJM80
    MJM80 Copenworld Member
    St Ives, Cambridge
    Copen Black 53 plate
    Ford Fiesta
    At the risk of stating the obvious is the boot roller cover clipped into place correctly as this will also stop the roof opening.
