Rear bumper removal
Discussion in 'Problems, Fixes, Tips...' started by copenjez, Apr 24, 2016.
Tags:
  1. copenjez
    copenjez Copenworld Newbie
    Does anyone have any tips? I suspect mine hasn't been touched in twelve years, so the fastenings on the underside are seized solid. In particular, any ideas for shifting the three screws (marked 'S' in the manual) at the top on either side? I've soaked them in WD-40, tried shocking them loose, with no success. The bolts on the two lower rear brackets are also locked solid ...
  2. copenjez
    OK - drawn a blank there! Had to drill off the heads of a couple, but it's off at least ... Next question - does anyone know if/where you can get the wee plastic clips that hold the rear tail/stop lights into place? The manual talks about removing the bolt (check!), and then levering it off with a spatula (also check!), but they don't mention the two plastic clips that snap in the process ...
