quarter window doesn't come up
Discussion in 'Problems, Fixes, Tips...' started by lex schotel, Aug 12, 2018.
  1. lex schotel
    lex schotel Copenworld Member
    Hi , My left quarter window is in the down position , and I would like to get it in the closed position .
    I dont hear the window motor , so the plan is to get power straight to the window motor to see if I can close it like that .
    so does anybody know where i can find those wires ?, and where is the window motor situated ?
    thanks
    Lex
  2. BarnsleyRob
    @lex schotel
    I appreciate your frustration but please try and keep to one thread or otherwise nobody will help.
    Have you tried disconnecting the battery to reset the window and roof ECUs ?
  3. lex schotel
    ok , my apologies , i thought that my previous post didnt work .
    yes I did take the battery out , and did open up the boot that could have reset the window .
    cheers
    Lex
  4. Rex
    Lex, just for your information, the window / roof controller module is located in the boot of the right hand side (when looking from the rear). You could check the multi way connector is secure and not water damaged from a leaking boot.
