Plastic Bumper Clips
Discussion in 'General Chat' started by PauliePaul, Apr 13, 2015.
  1. PauliePaul
    PauliePaul Copenworld Regular
    Bedford
    hello guys just a question about the plastic clips that hold on the front wheel arch splash guards... theres 2 types the ones with the middle bit you push in and the other type which looks like a round flat smooth shape with a tiny circular hole in the center... does anyone know where I can get some genuine replacements of the 2nd descriped plastic clips as I need some and want them all to be correct matching ?
  2. Number6
    copenforbusiness likes this.
  3. PauliePaul
    Bedford
    no not them ones the other ones... they are flat and circle with a small hole in the center close to the edge of the wings is where they are put into the wheel arch liner
  4. PauliePaul
    Bedford
    oh sorry didnt notice the second picture i think the second picture is the one im after though not 100% as i cant see the face of it
  5. PauliePaul
    Bedford
    number6 do you know where i can get the Daihatsu Part# 90041-89021 ? possibly in the uk ?
  6. Number6
    OD: 20mm
    L: 18.7mm
  7. PauliePaul
    Bedford
    yeah ! thats the ones :) do you know where i can get them from in the uk possibly ?
  8. Number6
    I'd ask the seller of http://www.ebay.ie/itm/10x-Toyota-L...mmet-Bumpers-Aprons-Side-skirts-/371106545560 for the measurements of his part (ohhhhhh matron!).
    If the L and OD are same (or very close), go for it. The part # is a Toyota part as well as a Daihatsu part (same thing). The same part is also listed as:
    90041-89021 (9004189021)
    90189-06013 (9018906013)
    90189-06027 (9018906027)
    90189-06065 (9018906065)
    Go forth to ebay / amazon, and you shall find the promised grommet. It's a fairly common Toyota part, so should be easy to find clones.
  9. PauliePaul
    Bedford
    thanks for the help
  10. Number6
    Happy to help.
    You might be able to find it as a different manufacturers part number. For example, when I was searching for Toyota Part # 90044-68320 (the ebay seller above's part fits perfectly, btw), I found the Mitzi part number... Far easier to find the items with the Mitzi part number than the Toyota part number, for some odd reason.
    The above seller was more than happy to tell me the dimensions of his 90044-68320 clone, and I've a feeling his version of 90189-06177 is what you're after. Yes, the L is different on his part, but it's being pushed into empty space so should mean bugger all.
  11. DaG
