Oil Filter Wrench
Discussion in 'Problems, Fixes, Tips...' started by Nedryerson, Aug 17, 2014.
  1. Nedryerson
    Nedryerson Copenworld Regular
    0.66 Copen 2003
    Fiat 500
    Good Morning Copenistas,
    I have only had one oil filter change since purchasing the car and my local garage charged me twice what it would have cost for a 'normal' car. (Actually when I called to find out if the car was ready I could hear the mechanic in the background swearing at the little chap!)
    So I have decided to do it myself but I need to know which oil filter removal tool to use. Apparently the Diahatsu tool is over £60.00 but Laser do a range of tools for a fraction of the costs the question is which one?
    http://www.lasertools.co.uk/item.aspx?cat=1056&item=3595
    I also need to know where to purchase the 'short' filter and again your advice would be gratefully received.
    Ned
  2. Number6
  3. Nedryerson
    0.66 Copen 2003
    Fiat 500
    Thanks !
    Is the 65mm the one I need to buy ?
  5. Number6
    It depends on the oil filter you are using, so I can't give you a 100% answer. It's most likely either the 65 or 68mm for nearly all filters
  6. dsb
    I buy my genuine Daihatsu filters from sg petch - not as cheap as a generic one but that goes with the territory.
  7. juliewoody
    juliewoody Copenworld Newbie
    Sunshine Coast, Queensland Australia
    2004 Copen
    I had a similar problem finding the wrench, but I found a good one and posted the details today. I use the genuine 68mm Daihatsu one. Good luck
