nearside quarter window fault
Discussion in 'Introductions' started by Humblehog, Feb 23, 2014.
  1. Humblehog
    Humblehog Copenworld Newbie
    Copen 0.7 2004
    I was putting up the roof and I then put up the windows (the quarter window goes first then the main window) there was a crunch noise. Now none of the windows will go up. I did the reset with the boot switch but no good. I was able to lift the quater window up with my fingers and the rest of the windows now work. However, the quarter window doesn't work at all. Any suggestions please?
    Hmm.
    I think your going to have to disassemble the interior & take a look at the mechanism.
  3. Humblehog
    Copen 0.7 2004
    Many thanks - I think you are right. I did take out the interior cover behind the passenger seat but there's not much to see apart from a couple of small access holes with plastic stuck over. I took these off but I still coulden't see. I think the unit may have to be taken out through the boot, but I haven't managed to find a workshop manual yet. I doesn't sound very promising.
    The workshop manual for the Turbo Copen can be downloaded from the Directory section of the forum. You'll need to wait a few days before you get access as your new.
