How to change the oil filter
Discussion in 'Problems, Fixes, Tips...' started by AFR0N1, Sep 12, 2019.
  1. AFR0N1
    A video guide on how to change the filter + how to change the filter the hard way.
    All parts and tools are linked in the video description.
    Tools used:
    Halfords advanced tool kit (Ratchet, Screw drivers, sockets (10mm, 14mm))
    TRIPLE QX Box Of 100 Ecp P/ Free Nitrile Gloves Medium https://www.eurocarparts.com/ecp/p/ca...
    Blue Roll Workshop Wipes https://www.eurocarparts.com/ecp/p/ca...
    67mm Filter wrench https://www.amazon.co.uk/Filter-Wrenc...
    68mm Filter wrench https://www.amazon.co.uk/gp/product/B...
    Parts used:
    Washer (90044-30201) https://www.nengun.com/oem/daihatsu/c...
    Oil Filter (15601-97201) https://www.nengun.com/oem/daihatsu/c...
    Engine oil (Shell Helix Ultra ECT C3 5W-30) https://www.eurocarparts.com/ecp/p/ca...
    I hope this is helpful :)
    TriVille and sunlover like this.
  2. welz
    Nice video..:):), think, was a lot of work. better use 5w40, and do you know, why the filter has an arrow or an Dai sign on the upper side? please use an torque wrench next time ;)
    and first oel , than filter, than back the the screw in the pan..
    this should not be a criticism
    Kai
  3. sunlover
    sunlover Copenworld Regular
    Ayrshire, Scotland
    Totally brilliant! What a great helpful video, that oil filter does look tricky to replace..wish you lived next door lol. Wish there was a thread just for instructional videos like this, deserves to be a sticky. Well done!
    AFR0N1 likes this.
  4. Flufinn
    Flufinn Copenworld Newbie
    Daihatsu Copen L880k
    Vauxhall Astra K
    Is this video available? Looks like it's been removed from YouTube but I'm looking to change my filter from the front end as I bought my copen with a larger filter already fitted and can't remove it through the gap underneath
  5. AFR0N1
    yes the video has been deleted from yt.
    the steps are as follows (if I rememer correct):
    -remove wheel arch liner
    -remove bumper
    - bolt behind number plate, 3 screws on each side next to headlight behind the wheel arch liner (look up), and a nut near where the fog light is on each side. I think theres some clips or something under the front corners of the bumper too.
    - disconect fog light/turn signal cables
    -remove intercooler pipe
    -filter socket on a long extension
    I wonder if it's possible to do this without removing the bumper and instead just removing the grille, probably wont be able to get the intercooler pipe off but, maybe the filter can squeeze past? or is it too tight? not quite sure, been a while since I went the long way of changing the filter.
  6. Flufinn
    Vauxhall Astra K
    Hey, thanks! Managed to do it without removing the bumper, lights or wheel arch in the end I was able to squeeze the filter past once I'd removed the grille and pipe and get a smaller one on that way
    Rex likes this.
