Hi! from japan
Discussion in 'Introductions' started by noel-forester, Oct 20, 2014.
  1. noel-forester
    noel-forester Copenworld Newbie
    impleza(GDB-A)
    Hi!
    I'm currently living in Japan,tokyo
    A new copen(LA400K) is release in japan.(2014/06/19)
    But I can't like that's new model...
    (because, heavy body, power less engine and very confort suspention,etc...)
    Do you have any opinions?
  2. threepot
    threepot Copenworld Regular
    Is yours a proper manual gearbox or a CVT?
  3. noel-forester
    impleza(GDB-A)
    I LOVE manual gearbox,ofcourse
    like connecting car,manually direct control and... if broken easy repair.
  4. dsb
    I like manual but this time it looks like the auto has better mpg.
  5. threepot
    So you want more power!
    What you need is an FCD, and some sort of increase in boost control e.g. bleed valve, or actuator or electronic boost controller.
    They are only 63hp/47kw because of Kei law, crank up the boost a bit and it will show its true colours.
  6. noel-forester
    impleza(GDB-A)
    If boost up on normal turbin, maybe can't over 80ph
    Because for equipped turbin (RHF25) is very small and that's engine is not high rotation engine.(bore/stroke ratio:1.12)
  7. threepot
    I think you will find all Kei cars in japan are limited to 140km/h which is about 85mph.
    Your limit will be caused by electronics.
    Maybe part of the ECU via the VSS.
    There are products on the market such as this http://pivotjp.com/product/speed/sml-v-e.html
    Here in the UK, we tend to remove all Japanese speed limiters when we import grey cars from Japan.
