Heater / Fan stopped working
Discussion in 'Problems, Fixes, Tips...' started by mickyblue, Feb 22, 2013.
  1. mickyblue
    mickyblue Copenworld Newbie
    Leeds, West Yorkshire.
    Copen Vivid
    Suzuki SX4
    Hi Guys,
    My Copen is a 54 plate vivid 700cc.
    Recently the heater / fan has stopped working completely.
    Its not even blowing cold air. I've tried it on each setting and nothing.
    I think the fuses relating to this are the one's under the bonnet but not sure which one exactly as it mentions 2 different ones??
    Just in case its not the fuse I've bought a heater fan (ebay) thinking it is an easy fix, does anyone know the process for replacing one of these please??
    Thanks in advance
    Mick
    Hi Mick,
    Section K1-8 of the service manual shows an exploded view of the heater. Putting the fan on the drivers side.
    It refers to section i2-22 to remove the instrument panels.
    If your lucky you might just get away with removing the lower panel below the steering wheel to get access to the fan. Either way you'll need to be a contortionist.
  3. mickyblue
    Copen Vivid
    Suzuki SX4
    Thanks Adam,
    Looks like its going to be a right laugh!! :(
    Before I get into the realms of doing that do you know which fuse / fuses it would be??
    I hope it's the fuse!
    Regards
    Micky
    The heater relay is no.9 under the bonnet, labeled htr.
    The picture on the lid of the relay/fuse box shows the position.
    I don't know if there is another related to the heater/blower.
    @Rex, as the forums electrical guru, can you confirm the fuses/relays? The handbook is vague with no key for the abbreviations used.
  5. mickyblue
    Copen Vivid
    Suzuki SX4
    Fixed;)
    Got in the car to go to work this morning and its working fine:)
    I'm glad I bought spare fuses and a fan motor for no reason!!
    Thanks for the input though guys.
