Grinding noise
Discussion in 'Problems, Fixes, Tips...' started by Kevin Batchelor, Apr 13, 2013.
  1. Kevin Batchelor
    Folkestone, Kent
    Hi Guys
    I get a grinding noise from the front left wheel when going round roundabouts!
    Could it be a bearing? It also happens when reversing tightly on full lock! The sound only happens when I am on a tight lock - but not when I am driving "gently" on the roundabout!
    Any ideas?
    Cheers
    Kevin
  2. Binz
    Binz Copenworld Regular
    North Hampshire
    Hi, yep could be bearing. Jack the car up so that wheel is off ground, then hold it top and bottom and see if you can move top/bottom in and out; if there is play then it is likely the bearing.
  3. Kevin Batchelor
    Folkestone, Kent
    I have booked into garage next week - I am sure they can sort it!
    Cheers
    Kevin
  4. Pitti
    Pitti Copenworld Newbie
    LHD Copen 1.3
    Are they the original tyres?
    I´ve got the same with my wintertyres. The tyres rubbing on the inside plastic cover. There is a flap sticking out at the top front side. You can shorten it or let the tyre do the job :D
