Greetings from Hong Kong
Discussion in 'Introductions' started by alcore2008, Nov 18, 2018.
  1. alcore2008
    alcore2008 Copenworld Newbie
    Hong Kong
    Copen 660cc model
    Hi everyone, I am from Hong Kong.
    I come here for some service information for my 660 Copen which I owned for 2 years.
  2. AFR0N1
    Hello and welcome!
    Here is some service information for the 659cc Copen.
    Oil change every 3000 miles
    Engine oil fully synthetic 5w30
    Oil filter change every 6000 miles
    Tire pressure 35psi
    Tires 165/50/R15
    After being a member on this site you will have access to a copy of the owners manual and service manual.
  3. Salieri
    What AFR0N1 said, but 5W-30 is only in the rarest occasions fully synthetic, most are made of group 3(+) base oils.
    At least in german jurisdiction oils have to be group 4 or 5 to be called fully synthetic (vollsynthetisch). A good example would be Ravenol VST 5W-40
  4. alcore2008
    Hong Kong
    Copen 660cc model
    Thanks for advice.
    What I actually mean for service information is I need the parameters for overhauling the engine due to compression loss on 1st cylinder.
  5. Salieri
    You could look at the service manual in the resources section
