Custom Alloys
Discussion in 'Problems, Fixes, Tips...' started by PauliePaul, Feb 2, 2015.
  1. PauliePaul
    PauliePaul Copenworld Regular
    Bedford
    hello just seen some rare alloys that id like to fit to the copen but unsure if they will fit... the specs are - 15" diameter, 7j, 32 offset and 4x108 bolt pattern though the same alloys have been listed as a 100 pattern
  2. stickypinkyfinger
    Buckinghamshire
    Widearch Daihatsu Copen R
    Race tuned Dinli 450 RS
    Suzuki GSXR600
    Hi there. The wheels sound like there are multi pattern 4x100/108. 15" will be fine but you will struggle with 7" wide with a 32 offset. I have 7" wide 17" rims with a 38 offset and they stuck out 1.5 - 2 cm out of the arch and rubs on bumper, lights and the side skirt so yours will stick out a bit more. Go for a higher offset and a thinner wheel, maybe 5 - 5.5" wide with an offset of around 40 - 43 and you should be OK.
