Copen Vivid
Discussion in 'General Chat' started by PauliePaul, Mar 22, 2013.
  1. PauliePaul
    PauliePaul Copenworld Regular
    Bedford
    was just wondering because the copen vivid is limited and has the limited red vivid paintwork does this mean as ive seen later 1.3's in red that they are also the same vivid red or did daihatsu paint these ones in a different red being that they aint the vivid's ? anyone know and also i was having a wonder at why in the middle of the sills is there that center piece that looks like it can be removed ? what is that because my guess is that you could put the jack there which is probz wrong and was concerned about why its even there for heh :D
    The plastic bits in the middle of the sills aren't jacking points.
    I think it's there just to conceal the join in the two sheet metal body panels.
  3. Lotuseater
    Lotuseater Copenworld Regular
    1.3 Copen
    The Copen is based upon the Charade platform, a number of common parts - if you look at the 3 door version you will notice the same plastic covers/ joint. As Adam has explained these plastic pieces are there to cover the joining of 2 metal panels.
    Regards.
    L
