Copen needs a mechanic!
Discussion in 'Problems, Fixes, Tips...' started by James Haxton, Nov 10, 2020.
  1. James Haxton
    James Haxton Copenworld Newbie
    TW13 4EL
    Copen 0.7 (2004)
    LD54 UYP
    IMG_20160201_161633_hdr.jpg Water pump replacement is it a problem?
  2. AFR0N1
    I had a quick look in the workshop manual (Section B6 Page 3) and it doesn't seem to be that bad of a job (all things considered) the water pump is one of the higher up engine accessories so should be easier to access than the alternator or a/c for example.
    It does recommend raising the engine a few mm to give more clearance.
    There are 4 bolts on the pulley and another 4 bolts and 2 nuts on the pump itself.
  3. James Haxton
    TW13 4EL
    Copen 0.7 (2004)
    LD54 UYP
    Thank you very much afron1.
    James.
